Brake Question
PeteNora
Ishpeming, Michigan
On the m-817 brakes if you lose air pressure for some reason will you still have brakes? If I understand correctly the air slave is an assist so one has to push the pedal not as hard. I know on vacuum or hydro assist systems you still have brakes just need to push harder. Just had to ask this question on the air over hydraulic system.
