joshs1ofakindxj
- 120
- 43
- SW PA
I put new shoes on the rear axle of my deuce because the old ones got saturated with gear oil. I followed the TM and the drive side is perfect but the passenger side is driving me crazy! I can't get the shoes on that side to pull in enough so that they're not rubbing the drum and causing a TON of drag when the bearings are tightened. The bottom cams are in the backed off position and the top adjusters are all the way to the backed off position as well, but the shoes aren't touching the top adjusters. Has anyone had this issue? Is it possibly getting hung up on the alignment pins? Should I slow the holes for those pins so the shoes can move in more? Or could this be an issue with the wheel cylinder?
