Brake shoe adjustment driving me crazy
Floridianson
2,531
Interlachen Fl.
Yea I old school it and just do it by feel starting at the bottom and no feeler gage. I also remove the jam nut off the bottom and never-seize the stud so it will always come loose adjustment is made easer.
277
Belton, SC
When I tried to use only the bottom adjustment to adjust 8 o clock the way you are supposed to, the closest I could get it was .035. It's like the shoe was off center in the drum.
277
Belton, SC
For reference, the TM says:
3. Inspect parking or service brakedrums (1) or (2) for scores or pits. If scored or pitted, measureinside diameter.a. Replace parking brakedrum (1) if inside diameter is greater than 13.41 in. (34.06 cm).b. Replace service brakedrum (2) if inside diameter is greater than 15.0 in. (38.1 cm
