MILRET45
- 1
- 8
- LA GRANGE, TX
It must just be me since I have done several searches and can't find anyone who has had a problem re-installing the deuce brake shoe return spring. I popped the spring off for a wheel cylinder replacement using the larger Lisle spring removal tool with no problem. However the return spring hook falls too short of the attaching hole in the brake shoe to use the slot on the end of the tool handle designed to hold the spring and leverage it back in place.
All other brake parts are installed in normal positions.
I've used a Lisle spring plier on smaller vehicles with less spring tension with no problem.
