sandcobra164
- 321
- 83
- Leesburg, GA
Well, trucks back together now. I seem to have run into the "Chinese Outer Seal" issue that I've read about. The hub doesn't get too hot, just warmer than the others. I'm certain of the wheel bearing grease and the bearing preload since I've read quite a bit on doing this project. I looked at the old seal and it has a grove worn into it from the outer cage of the bearing. Is it possible that the new seals just have to be broken in some? I read about pressing them outward 1 mm as being the cure for one member on here so that may be an option. Any thoughts would be appreciated. I'm wondering if a few short trips would cure the hub and plan on trying that route.
