dragonwagon
- 4
- 0
- west branch Mi
Buying my 1st deuce ( 71 jeep ) i have no idea how the brakes should feel . They stop the truck fine , pedal is up at the top . Fluid looks good and is full . Iv driven it quit a bit with no issue but how should they work ?
Today while playing in the snow in the yard they changed abroptly . while the pedal has always been near the top the brakes felt like an old truck with manual brakes . Today i hit the brakes and the pedal was much softer like a car with power brakes . Release the pedal and i hear air release which i never did before .
Question is , how are they suppose to be ? Did something go wrong today , or did something start working correctly that was perhaps hung up in the past ?
When you use the brakes , release brake pedal should i hear a small release of air from the airpack ?
Does the deuce normally have a feel of power brakes or simular to a pickup that had manual brakes ?
No leaks i can see , fluid is full and the tandems will lock up much easier then they did before .
I had to work a 11 hour day so i only took a quick look at it and parked to get to work .
How something should work is not in the TM , its a matter of experience that i lack being my 1st military truck .
