Brakes locking up M923A2
jeremy turgeon
west covina ca
just picked up a m923a2 on the way home the breaks where locking up when i would hit the break and wont release when you let the truck sit for about 20 min they are fine. and the green air line under the truck that feeds the breaks and they release. any help would work thanks
M35A2-AZ
382
Tonopah, AZ
I know this sounds off the wall, but make sure your vent on the front services side glad hand is open and it is working.
If there is a ball valve there open it. the truck needs to vent out the front service glad hand when you release thebrakes.
It happened to me and that was the problem.
If you drain all the air out of the truck and then air it back up does it work ok then?
582
Dubois, Wyoming
what he said
jeremy turgeon
west covina ca
Went out this morning to move the truck and the breaks locked again. I cleaned the glad hand and been through a lot of other valves and i keep finding sand in everything. any other ideas would be appreciated thanks
