Brakes shoes slow release
Robin Strong
20
Idaho county
I've been having problem with brakes showy retracting.
I've rebuilt the air pack and master cylinder and power bleed system. Had good flow no leaks and all fittings are secure. Installed new brake peddle retention spring, was missing.
All that is left now is wheel cylinder. Next is cheap and adjust shoe clearance.
Be worth while to rekit if cylinders not to far gone?
Thanks in advance for worthwhile responses.
I'm confident that Air pack and master cylinder are done correctly.
18operator
1,855
Seville, Ohio
It has happened to me also. More pressure when applying the brakes opens up the flexible hoses. When brake applying is released the hoses swell shut holding in hydraulic pressure at the wheel cylinder, almost like a line lock.
frank8003
4,984
Ft. Lauderdale, Florida
It would be wise do renew or refurbish brake cylinders especially if one does all the work to get to them.
The brake cylinders work best with the proper rebuild parts, lots of information here in SS about that.
Also check to assure it is all working as per design when you get it apart. I can send to you videos and such in the email but can not attach those files in SS.
Send message, I will send the videos.
frank8003
4,984
important stuff
try search military truck wheel cylinder kit in the online auctions
cattlerepairman
3,276
NORTH (Canada)
This post also has a few tips. https://www.steelsoldiers.com/threads/brake-frustrations.198123/
Can't hurt to remove the splash plate of the MC lid and also check with a flashlight that there is a vigorous stream of brake fluid returning to the MC when the brake pedal is released. Should see the brake fluid well up in the reservoir. Return hole is at the bottom, fairly far to the rear, if memory serves.
