breakers
junkyardog
wakefield new hampshire
are there breakers in all the circuts in the 5 ton. meaning the transfer fuel switch, horn. fuel heater. i would like to tap into wires to run plow lights and flashers. they are not used while driving.also does a flasher know if its 12 or 24.
jatonka
57
Ephratah, New York
Breakers
What 5 ton? M39 series, one breaker...the horn. One fuse.... in tank fuel pump.
Does the flasher know 12 or 24 volt? Ask one...... or hook up a 12 volt in a 24 volt circuit, it will tell you right now. JT out
