Breaking Spring Brake tubes
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Do you need this bracket? I think that bracket came with the T-case I picked up at the rally. You can have it if you want.
Naw. I had a few spare transfer cases laying around. Thanks though.
Sent from my SM-G860P using Tapatalk
simp5782
9,509
Mason, TN
Installed new brackets and still using the old style. I will not be able to put a bracket down near the backing plate. Too much of an angle. 20170101_164457.jpg20170101_144431.jpg
simp5782
9,509
Mason, TN
Updating this :
Installed a new transfer case with new bushings. Still had a vibration under slight throttle. Removed the rear transmission mount and replaced it with a stronger rubber bushing. Vibration is gone for the most part. Still have one, but it is in the floor and cab now. Before you could feel it in the pedal. Not anymore. So on to body cab rubber.
Put about 4200 miles on it. No broken brake tubes yet. Brakes work as designed.
Jbulach
2,400
Sunman Indiana
I know you just replaced some driveshafts, did you replace the transmission to transfer case as well? If not you might try swapping it out, if you have another one laying around. Also check the u-joint timing and angles, they should be as close as possible to each other end to end.
simp5782
9,509
Mason, TN
With the transfer case in neutral and in drive i run it up to 2100 and throttle check it and there is no vibration i can feel. The joints on the jack shaft were replaced about 8months ago. I am thinking it's body vibration cause i can feel it more in my left foot on the floor and thru my seat frame than i can the gas pedal.
Jbulach
2,400
Sunman Indiana
Ha.. that just gave me the thought of putting one of these bad boys up on blocks just to see how it feels! Fortunately mine is pretty smooth though, so we'll save that project for another day.
Maybe those guys with the drone problems could try it with their truck pointed at the neighbors house, that might get some attention!
