- 8,682
- 3,087
- 113
- Monrovia, Ca.
Went to the MV museum today...finally got some free time! Craig decided to resurect the M123 first. Had to drag it out of the hole it was in. It had settled down into the dirt about 4 inches all the way around. Had to use a 4wd fork lift to get it out. They do NOT like to steer w/o the engine running! Got it back around back to the shop area, checked fluids, changed the upper radiator hose, checked the air filter for varmints...there were remains of some sort of fairly large fowl in the cab! Gave it some fresh Penray coolant, batteries, pumped the primer a few times and hit the button! At first, just click, click
Cycled the power switch, hit it again...WOO HOOO, Smoke! Good o/p, no miss, smelled a little of oil, but that soon changed to the sweet smell of Cummins naturally asperated smoke. Ran it a bit, gave it a little bath and took it for a short cruise up the driveway. It steers ALOT better with power behind it! Craig let me drive it out of the shop area over to the M578 we tried to get up and running..needs batteries...next time
I have a few vids of it..gotta put them on you tube, then i'll get a link posted.
