Brad
- 113
- 43
- Bolivar, Pa
My Son, in his zeal to do good while draining moisture thought it best to remove the petcock and get rid of every last drop of water. Well we know what happened, broke off the petcock.
It is in a hard place to get at but we tried "easy outs" with no luck, the brass left in the threaded hole just keeps getting cut out. Finally we got a big steel lag bolt tight in the brass and it is holding air , and was enough for him to get the truck back to its storage location.
I might be able to just tap some threads in what is left of the brass and run a real bolt in it and seal it.
Do you think that sufficient? Otherwise I'm going to have to remove the tank so I can get at it better to remove the old brass and clear the original threads in the tank then get a new petcock??
Valued opinions please.
