JohnFire
- 4
- 18
- Pottsville, PA
Just called Colemans today, to make sure they still had them. They do and they are $395. I checked their site the same day it happened.
How hard are they to change if you have the truck up on jackstands. Correct me if I am wrong but my thought is that it should be easy. Make sure it is full of oil, unbolt it from the springs, the shocks, and the driveshaft. Disconnect the brakelines, roll the axle out of the way. Roll the new one into place. Connect everything, bleed the brakes bolt it all up and done. My count is about 14 bolts for the whole thing. 8 for the ubolts, 4 for the driveshaft, and 2 for shocks.
Tips tricks and general info would be appreciated. Then I can get it in for the oil change.
