Build an adjustable tire lift for Deuce.
foxtrot
3,258
france
For all your trucks.
All dimensions are in millimeters.
To save time I started the construction by the base of an engine support which sleeps at the bottom of the garage.
I retained :
- An adjustable hydraulic cylinder.
- A cutter diameter 32mm 11/4
- Tube diameter 30mm 1.181 inch minimum
- Square tube 60x60 and 70x70mm
I will be using the tire lift throughout my rebuild see link below.
https://www.steelsoldiers.com/threads/my-first-multifuel.207571/page-8
