Building a Long bed bobber
cummins7
Spring Grove, Pa
Unfortunately I was in a hurry to get it going and built my own 1 piece driveshaft. I haven’t had any problems so far and have taken it off-road and crossed a couple creek beds with no issue. Only problem I have is a slight vibration from 40-45mph but that could also be the tires or something else. I do plan on adding a carrier bearing and making a 2 piece shaft but can’t find any info on a known part number or seen pics up close of someone’s setup...
DB556
129
Ambridge, Pa
I'll have some pictures soon as the parts are in I ordered a rear drive shaft in that I will have shortened the width of one axle input flange to flange plus the length of the mid propeller shaft so I'm guessing 23" shorter.
Along with a set of axle flanges and pinion shaft for fabricating the carrier bearing, for the carrier I'll be using a pillow blocks from a NPR box truck the seem cheap enough
and they come with a nice rubber dampener. Also they seem like the right size when I'll see when they come in.
I'll use the shortened shaft after the transfer case, the stock shaft will go to the axle. Both shafts will have a slip joint so that should allow for some frame flex from the transfer case.
tobyS
836
IN
BB556, I haven't completed mine, parts are at the machine shop (sidetracked). Rusty commented above on it also.... the carrier bearing.
I went with a slip joint to accommodate transfer case movement that without it, pushes and pulls on the output shaft of the transfer case. I rebuilt the TC on my 817 because of bearing play on the TC shafts and don't like pushing or pulling there, which contributes to bearing or seal wear. Maybe the rubber bushing on the carrier is enough to take any movement when it's not a slip.
With a slip on the front section and the slip on the rear, that rubber is what is holding the position for the mid-section. I decided to make that a solid bearing mount (w/setscrews), to resist any longitudinal movement. What that may do is transfer some drive-line noise or vibration more into the frame. It is a steady position for the front of that section. I will be having it balanced, but the machine shop I use is really good at getting them straight and we don't think the solid mount will be too noisy. I have a rubber one I could mount if it is excessive noise.
