jesusgatos
- 28
- 38
- on the road - in CA right now
Nice looking setup. Is that PSC's bolt-on ram-mount? Why did you switch the outer TRE's to heim-joints? What pump are you using?
I am running the same setup on my deuce; there is actually a tapered insert in the steering rod that adapts the taper to a straight 3/4" bolt. It works great.Looks like just bolts on the ends of the tie rod and not a tapered ball joint. If that is the case I don't like that.
