Built an anti wrap setup on my bobbed Deuce
rizzo
9
Port Huron, MI
..I climbed a small dune and bent the longside pipe. Schedule 40 that long will bend :) .
make it into a triangle shape (or V) instead of a Y shape. That will keep your top pipe from bending. also put a couple of cross pieces in the middle. also on is V shape.
samsimpson
Corpus Christi, TX
I was going to add another piece, which is much thicker wall, from the bottom axle mount area all the way up to the shackle mount area. Essentially the current bottom link will act as the axle side brace, I will put another one toward the front end. I should be able to do it this weekend. Will take pics.
