blzrgb
- 1
- 0
- mississippi
Hello. One of my 1008's has picked up a slight burnt valve sound out the drivers side pipe. It runs fine but it smokes out that same side when you start it. Doesn't smoke at all going down the road. The startup smoke could be valve guides and seals but whats the best way to check for a burnt valve other than pull the head or hold a dollar bill at the pipe? Are the 6.2's known to burn valves ? The pump and injectors are stock. thanks.
