Cab lift hydraulics
Suprman
677
Stratford/Connecticut
I believe it's self bleeding the pump and reservoir are one. Are you having an issue with yours? If you see puffs of "smoke" coming up then your internal pump seal is bad and will need to be rebuilt. There is a thread on it.
Lmtv772
Banned
651
Florida
That's not my issue. My issue is after rebuilding the pump the cab doesn't want to raise, and when it did, it didn't want to drop back down. Making wonder if there is air trapped inside
Andyrv6av8r
455
Spartanburg,SC
I would think if there's air in there, it would nearly fall back down . Same issue with the hand pump?
Lmtv772
Banned
651
Florida
it doesn't raise only to a certain point, so Yes I am sure there is air in there, but how to get it back out?
And yes, the same with the hand pump otherwise I'd think it's the air lift pump
dalej
Blue Hill Nebraska
You can try to unloosen the fittings at the cab lift cylinder and see if air or oil comes out, pretty much like bleeding the brake line on a car. If you have air in the cylinder most of it will come back to the reservoir when you extend/retract the cylinder all the way, it has to move all the way in and out to clear it. If it's not raising all the way, check your oil level when it stops moving.
Suprman
677
Maybe run it with the reservoir cap off. If there is air in there one would think the space taken by air would be exchanged for fluid and the reservoir level would go down a bit. I took mine off and no air got in the system I didn't have to bleed it when I put the new one back on.
dalej
Blue Hill Nebraska
Does anyone have any idea where the rebuild on this pump is?
