- 10,350
- 92
- 48
- Meadows of Dan, Virginia
I don't know where the link to it is, but I downloaded a version last year and would like to list errors that I have found. If you have found problems with it go ahead and list them here. When used for troubleshooting, an erroneous/incomplete diagram doesn't help.
BTW, the wiring diagrams in the TMs also contain errors....
1) The starter solenoid contacts and coil should be flipped, wire #214 should go to the coil not the contacts.
2) The light switch is drawn without circuit breaker.
3) Oil pressure switch in start circuit is not always present. State year when used.
4) Minor point, perhaps, but the blue color should be changed to black for easier reading.
5) Some ground straps should be identified as to location. This includes grounding wires that ground components, like the radiator. Tha dash is grounded via mounting screws and should be noted.
6) Turn signal indicator lamp should be grounded (via mounting strap,actually). Note to self: Check this.
7) Flame heater ignitor unit not drawn correctly, it contains a vibrator and capacitors.
Master switch identified as "Ignition Switch".
9) Flame heater circuit should include a circuit breaker.
10) All light bulbs should be shown with part numbers.
11) Fuel tank ground is not shown (ground return for level sending unit).
12) Van body and pipeline BO and clearnace lights shown witout ground circuits.
I know that a lot of effort went into producing this drawing, but revisions are part of life.
View attachment wiring diagram Model (1).pdfView attachment Deuce_Wiring_Schematic_PDF.PDFView attachment Wiring Numbers.pdf
