Cadillac Valve & TDM Keeps Burning Out
Hummer Guy
807
United States Louisiana
This is going to be my 3rd cadillac valve & TDM, I've had them burn out twice, my first one lasted around 3 weeks after I installed my aluminum radiator and the 2nd one lasted a month, does anyone know what amps the cadillac valve & TDM put out? I would like to put a fuse or circuit breaker in between the two.
Coug
4,351
Olympia/WA
only reasons I could see for them to burn up/fail like that is if there is a wiring issue somewhere, or if you're buying cheap chinese made crap.
What voltage are you seeing on the wires going into the TDM?
I find it unlikely but any chance you damaged any wires when you were installing the radiator?
Mogman
9,569
Papalote, TX
Those things are pretty much bullet proof, as Coug eluded to are you sure you are buying the genuine article, there are tons of aftermarket stuff that look pretty dang real.
The only other obvious thing would be if your alt. was grossly overcharging, but I'm sure you would notice if it was that bad.
Hummer Guy
807
Haven't check the voltage in a long time, if I remember, it had no voltage going to it, its been about 2 or 3 months since this one burnt out, I'm just starting to address it again since cold weather is coming
Hummer Guy
807
Hummer Guy
807
The ones I get come from black dogs custom, they seem to be pretty good quality, my alternator charges between 28-29 volts
TOBASH
3,480
Brooklyn, NY
My concern is water fording.
Anyone here convert to an electric fan clutch activating system?
Retiredwarhorses
4,178
Brentwood, Calif
all Vehicles have a fan blade, all off road vehicles go in water, there is a proper way to Ford a water crossing, and it’s not
what you see on the internet when you drive through a deep puddle at 20mph like an idiot.
TOBASH
3,480
Brooklyn, NY
True Steve, but I don’t behave like that. I’m interested in an electric fan clutch. Do you know of any?
Hummer Guy
807
This was slightly my plan; I was going to use dual fans to turn on at 180-190 Degrees, but I was going to keep the regular hydraulic fan connected to be a backup for when the electric fans can't keep up or if they fail. The fan I have is 2215CFM for each one, so in total its 4430 CFM, from researching, the humvee original fan pulls about double that.
Retiredwarhorses
4,178
Brentwood, Calif
stay away from electric fans…it’s been proven for 20yrs they do not work on this truck.
I lost count on the number of trucks I’ve removed these stupid cooling fans guys stick on the radiator stack, they block airflow, the best fan is the OEM fan.
