Camp Lejune mk17 hitch needed? Tow off base possible?
turnerman
13
landrum, sc
Does anyone have a hitch for the mk17 rear units? Need to tow one from Lejune. I have a hitch but would have to weld on. If I can't find an original hitch is there anyone who could tow an mk17 off base to a staging point I could weld the hitch at?
peecook
Richmond VA
there was a pallet of them that sold out of NC a couple months ago. not sure if anyone knows who got them, but there were probably 6 could figure out why the didnt put them on the 20+ trailers there without the hitches. good luck
turnerman
13
landrum, sc
Thought I would either put the crane on one of my dueces or cut the rear off a duece and weld the mk17 to the duece front. Got to get it home first!
ssspot
Columbus OH
Turnerman, which crane did your mk17 have? The one with the winch. Any problems with GL on the pick up , did they stick to the Monday only? Was Jimmy Wrecker ez to work with? Ru close enough to inspect the current lot at Lejuene?
554
Sedona Az.
One inch steel plate, stencil off docking plate, water jet, 12 inch C channel, lots of steel cross members, more one inch plate, 2 inch water jet hole for adjustable pintle eye, 45,000 lb pintle (a little light) and about 5 boxes of welding rod. Pulls like a dream, what color should I paint it??
BKubu
1,088
Gaithersburg, MD
MD: Thanks for the kind comment. I don't have one of those babies, although I drool over them everytime they come up.
BBBC: You should sell them. I might buy one. How much?
554
Sedona Az.
Thanks BK, for the words of encouragement, I don't think I have the welding knowledge to take this kind of project to the next level. The entire unit could be bought however, it is in brand new/never used condition from its Oshkosh referbishment, has bows and now a good way to tow.
OshkoshJay
Banned
dallas
I'm sure this has been asked and answered, but I really need the help. I'd like to find the MK17 hitch ... or the plans to build one. Anyone drawn a plan. I have the welders.
Ideas? What about building a 'gooseneck' to bolt to the front of the MK17, so to pull with a '5th wheel tractor'. Not to excessive, but wouldn't that allow the tractor to pull the gooseneck (bolted to the MK17) as #1 and on the pintle a # 2.
554
Sedona Az.
Gooseneck sounds good, to do the welding it was my experience that the thick steel needed so much heat that it moved alot when welding it. In other words you need trailer to bolt on and off as you fab, just doing it from stencil/drawings might leave a racked and twisted hitch for your end result. I would surely welcome the more experienced welder/fabricaters to chim in here with a better wheel. Mark
