can a 60 amp Alternator be swapped out with a 200 Amp Alternator without any mods?
Milcommoguy
2,422
Rosamond, CA
Note that the 60 AMP alternator have a little more going on inside with mechanical and electrical issues. Brushes will wear, weak springs, dirty slip rings can lead to wonky (technical term) output. Where as the 200 amp units are of a brushless design eliminating these wear items. Nice to have but not a big deal, BUT it is a BIG DEAL IMO.
Both can have wonky output do to a zapped regulator, diodes, winding, soldered connections, etc
60 amp trucks are wired thru the PCB and its body connector / wiring harness. Good idea to check this plug and contacts for poor connections, looking for bent, burnt, loose, corroded, poor fit-up or just plan nasty as they are both male and female parts to this poor design for a charging system. Just more crap to go wrong at the wrong time... not to mention FET / relay, control circuits in the PCB.
Once it is determined 60 amp er is at fault, most of the action can be rebuilt with the CORRECT back plate holding the brush and regulator assembly.
Don't forget to disconnect batteries before starting ANY work and double check all connection. There's a couple that are CLOSE together under the little cover. (cuss area). Clean or upgrade grounds system.
Good luck and charge on, CAMO
good
Huntington Beach
Thanks for getting back to me fellas the actual generator I have is a 100 amp 28 volt generator with the long regulator on top of it and as I said before when I first start the car it's in proper charging form after a few minutes to slowly goes down to yellow and stays about halfway in yellow from there occasionally it goes back up to Green but never into the red on either side but it doesn't bounce back erratically
Milcommoguy
2,422
Rosamond, CA
Not sure on the 100 amp alternator. I think ?? (sometimes) that it is a odd ball unit with not as many out there. Could be expensive$$ ? Might be time to go with what fits? If a 60 or 200 amp unit will drop into existing hardware? IMO. Wiring should be easiest part.
Trying to hold on to my wallet and drive a HUMMWV, CAMO
