porkysplace
- 1,494
- 113
- mid- michigan
The Air shift transfercase turns them the same speed.As I understood it, the axle ratios are the same, but the front and rear outputs from the TRANSFER CASE turn at differing rates.
Can anyone knowledgably CONFIRM or DISPROVE this????
Thanks.
John
I was under the impressing that the air transfer case ONLY engaged the front axle, but didnt actually lock the axle making both front wheels turn at the same speed. I mean you can engage the two front wheels sure, but for the 2 front wheels to rotate at the exact same speed and achieve that "hopping" you talk about would require a differential lock on the front axle.It would be different than driving a front wheel drive car. They have CV joints on the axle shafts.
The deuce will try to hop in the hard turns on pavement and it's kind of hard on the knuckle u-joints but it can be done.
Its hard enough to maintain highway speed with the rear axle powering the vehicle!Wreckerman;
That's for when you have both the front and rear engaged together. No fast or Highway speed driving with the front axle engaged!
Sir, It scares me as well but I do enjoy the fact that the OP came here to ask his question. I'm sure many other's operate these things without the friendly advice that can be found here on SS. I'm sure you know as I do the the "emergency brake" on these trucks does no good so ensuring you have a great braking system is a must.Don't mean to be cynical but it scares me to think people are driving around on public roads in a 14000lb vehicle with little or no knowledge of the mechanical workings of their vehicle. In nearly all instances, we are our own chief mechanic. As to the initial post, knowing it will handle differently, make short trips under mild conditions, be gentle and drive it till you get your driveshaft built. Many areas like mine don't have driveshaft shops on every corner. It took me nearly 2 weeks to get mine built. To my beginning comments maybe I was actually blessed to drive and maintain junkers for most of my life. Read, Learn, us any spare money to buy tools and ammo in reverse order.
I wouldn't think the limited power of an M35 etc would actually exhibit that much in effect of torque steer with its big wheels etc. I mean I can clearly see it and feel it if I go full on the throttle on my VW Passat with 140 HP. But again that would be as comparing apples to oranges, due to size and weight difference of the two vehicles. Not that torque steer doesn't happen, I would just think its less then what one might expect in a smaller and lighter vehicle with same amount of HP.Sure, Front Wheel Drive cars suffer from "Torque Steer" when you slam the throttle at lower speeds but you can adjust your driving habits to accommodate or you can anticipate it and hang on to the steering wheel a little tighter.
