Michael
- 24
- 38
- Fulton, MS
The NAPA part number for the 24 volt bulbs is 1662. They are made in China by Federal Mogul for NAPA. They are 24v 32/6CP. The store here had to order them but they came in the next day.
Steve, this will not work as there is check valves in the lines. If you were to get under the truck and look at the airpak/mastercyl combo, you will see where the air goes in the back. Just take that out and run air from the gladhand in. Brakes should work. I say this because if the towed truck is un-known there could be all kinds of problems with its brakes.sermis said:What about brakes on the towed vehicle? I remember a post where you can tap into the air system around the master / air pack. Would it work to run air lines from the rear glade hands on the front truck into the rear glade hands on the rear of the towed vehicle and back flow the air for stopping?
