Can I run 12 volt LED's from a single battery on my MEP802?
Ray70
7,181
West greenwich/RI
No, what Kurt means is that you want to switch the 24V power going into the converter, not the 12V power coming out, otherwise the converter is constantly sucking up power even when the lights are off.
Depending on what size converter you get that would mean either a switch or a relay feeding the red input wire.
