Can not get the fuel filter off
moriboy
22
SW OR
Actually, you don't spin the filter housing. There is a bolt on top of the housing that you use to tighten/loosen the filter canisters.
1,172
And you torque the bolt correctly or they leak or break.
All in the Tech Manual
JeffAS
Lessburg/Ohio
I did remove the bolt but it does not want to come off, tried to spin it but still could not move it but it is cold out going to put the bolt back in and start the Deuce to let it warm up and try it again
glcaines
2,482
Hiawassee, Georgia
Undo the bolt and tap the side of the housing with a small block of wood or hammer handle. Don't hit it so that you dent the housing. It will pop loose.
