Can someone confirm soft top measurements
tgejesse
289
Maryland
I bought a 4 man kit from SECO parts and I’ve received a bad passenger side rail twice now.
First,
Has anyone had this experience?
Second,
Can anyone confirm the measurement center screw to center screw from b pillar to a pillar where the side rail mounts? I measure 33.25 on both driver and passenger.
When I measure the rail holes on the (now twice) wrong side rail, I measure 32.75 from center hole to center hole.
I’m going nuts but I just think this Chinese crap is just made entirely wrong.
Maxjeep1
1,930
Las Vegas Nevada
First,
Second,
I can measure the rails they sent me last week. I don’t know if that helps you very much.
tgejesse
289
Maryland
I’m willing to bet what you have matches me because I now have 2 from him that are the same (but wrong).
If you paid anything near what I paid, you might wanna try to install your rails ASAP cause if multiple of us are seeing the same thing it makes me sound less crazy.
Maxjeep1
1,930
Las Vegas Nevada
I have 33” to 1st hole on one and 32 3/4” on the other. The notch for the b-pillar is off the same. I don’t have my truck yet so I don’t know what is the right one. Look at the quality, was wrapped while paint was wet. We paid a lot for that stuff.38713CCE-485D-47D9-B15B-AEA1142A8924.jpeg240D51F5-82D2-497F-8F56-7C03B5300DDC.jpeg4E95F2FD-D347-4CEC-B3DE-E3EA4EF91BEF.jpeg
tgejesse
289
Maryland
Action
1,564
East Tennessee
Are the seco parts marked LH and RH like the originals? It was in the metal.
The windshield frame is on hinges. It tilts front to back. Loosen all 12 bolts of inside w/s frsme hinges. Pull those 2 pins out. Attach handrails (if they fit). Reattach all the hinge stuff. There are shims behind the upper inside hinge. You may need more or less shims.
Maxjeep1
1,930
Las Vegas Nevada
That would probably get it to fit but it’s not what you should have to do considering the amount we paid. That will change door gap also because the difference has to go somewhere. I don’t understand how you can make a part wrong when you have what it should look like right in front of you.
I didn’t see any L or R on them
tgejesse
289
Maryland
Second this.
They are not marked, they are clearly aftermarket.
My concern loosening up the windshield / b pillar to try and make everything fit, is going to throw everything else out of alignment.
I have to call SECO today again and see what we can agree on.
tgejesse
289
Maryland
If anyone else is having problems, call SECO. Despite this inconvenience, they handle their customers well. No bad blood.
Retiredwarhorses
4,635
Brentwood, Calif
For those who have never installed an OEM top….your going to find fitment varies from truck to truck even with OEM top kits, so unless you have attempted to fit your aftermarket hardware, I would not pass judgement so quickly.
ots not uncommon to have to cut or grind a bit to get this garbage to line up.
ive installed hundreds of kits in the last 30yrs.
Maxjeep1
1,930
Las Vegas Nevada
I completely understand that we are not building a watch but both rails should be a mirror image of each other. If you start with a rail that’s already 5/16 out and you are installing it on a vehicle that’s a 1/4 out the other way you are a 9/16” from fitting. I don’t think it’s unreasonable to want rails that are the same dimensions unless they are being advertised as rails that are pretty close to being right. I wouldn’t have bought them knowing that. The nut serts are not the same width apart so bows will need to be wallard out a 1/4” and the top clips are off also but that’s not a problem.BB933CAA-4B59-40F2-983B-71EE5103AC5E.jpegC30FF62A-7A39-41CA-82EF-1C86895B9058.jpeg
Retiredwarhorses
4,635
Brentwood, Calif
I completely understand that we are not building a watch but both rails should be a mirror image of each other. If you start with a rail that’s already 5/16 out and you are installing it on a vehicle that’s a 1/4 out the other way you are a 9/16” from fitting. I don’t think it’s unreasonable to want rails that are the same dimensions unless they are being advertised as rails that are pretty close to being right. I wouldn’t have bought them knowing that. The nut serts are not the same width apart so bows will need to be wallard out a 1/4” and the top clips are off also but that’s not a problem.View attachment 840202View attachment 840203
so as I understand it, you have not attempted to install this kit on a truck but your convinced it’s not going to fit?
you have never had an OEM kit nor installed one to compare it with the kit your bought from SECO?
just trying to understand the logic…
Maxjeep1
1,930
Las Vegas Nevada
Yes you are correct! The only thing I’m convinced of is that the pieces should be a left and a right and they should be the same dimensions. So you are saying that they intentionally make them different so they fit the trucks better? I have zero problem loosening ever pillar I have to make it fit but I’m not doing that to make it fit a part that’s obviously made wrong
Retiredwarhorses
4,635
Brentwood, Calif
no, I’m saying maybe Attempt to install them first…but yes, there are left and rights of the side rails.
im just point out “as I did in my first post” even the OEM kits often require some fudging.
Maxjeep1
1,930
Las Vegas Nevada
I’m pretty sure I can get it to fit if it was 1” out then I would just need to trim roof a little bit and the doors and add onto the other door and stick a cat in the gap. That’s just not how I do stuff and I don’t use vise grips on bolt heads either. I don’t think less of anyone that does or is willing to do it. Even with the perfect rail it’s not going to fit but at least you are putting it where it should be not to where it shouldn’t be and even if they were both off but the same I’m ok with it. Everyone just has to build what/how they want and end of the day if they are happy with it that’s all that matters. You are probably right and I could change my mind once I get my truck.lol maybe I will go buy a new pair of vise grips
Edit:
The parts you sent me are perfect and I couldn’t be happier! Thanks
tgejesse
289
Maryland
I have. Hence why I posted this thread. The measurements are off to where the rails aren’t even close. I didn’t even get to testing the bows because.... the rails wouldn’t fit.
Nothing is ever perfect, but these rails are outside the parameter of acceptable.
Action
1,564
East Tennessee
Did you swap sides and try to install.
And, yes, the factory rails are nearly mirror image of each other.
A while back, someone posted pics of their softtop not fitting. The velcro was inches from reaching the bows, light could be seen thru the seams and the rain gutters were wavy. Does anyone recall where that top came from?
Maxjeep1
1,930
Las Vegas Nevada
Seco is where we got the c-pillar and hardware kit. C-pillar has a number stamped on it and that gave me piece of mind until this
gringeltaube
Staff Member
2,695
Montevideo/Uruguay
.... One of our house rules: • Do not post unfriendly or insulting comments or replies to other members., This can start unpleasant exchanges which no one wants to read in an otherwise valuable topic.
