Can this be right ????
Scarecrow1
Florence , S.C.
I am looking to pick up a trailer soon so I was in the research stage. Better known as window shopping I have an SUV with a pintle hitch,so I can pull it home . The next point to think about is the weight . So I checked the 3/4 ton M101A1 it's weight is Est 3,160 lbs, ok so I look up the weught on the M105A2 1&1/2 ton its Estimated at 2,750 lbs . Thats twice the haul load as the 3/4 ton but its minus 410 lbs . Can this be right ????:roll:
Tackettr
Edmond/OK
I would say the weight is wrong. Which one are you getting 101 or 105? I pulled a 105A2 with my GMC Envoy (6 Cylinder) with no problems. Used magnetic taillights & an adjustable pintal raised as high as it would go. If you have to go far I would pull the cover off, it creates a lot of drag. It was tough for my 6 cylinder to keep it at highway speeds.
1,172
It could be a typo , The stats came off the GL site. But all the trailers stated the same est weights minus the 410 gap
Never go by gl descriptions
The trailer TMs have their weights listed in them.
