- 8,698
- 3,205
- 113
- Monrovia, Ca.
For all you Canadian vehicle guys, Had a chance to work on and drive a 12 May, 1942 made 15CWT truck. It had been in the back 40 for years. Drug it to the shop, checked fluids, surprisingly, the brakes WORKED and the fluid was clean and clear as well as a great pedal! Put a battery in it, cranked, no spark or fuel, Checked the points, they were white and corroded. Cleaned them up and got good spark. Got gas to the carb, but no squirt. Ran for a second putting gas down the carb. Pulled the top, float bowl full of debris and the accelerator pump hard as a rock, It is a leather one. Pulled the carb, soaked the pump in air tool oil. Pulled the carb apart, for a 1 barrel there sure is a lot of parts in there! Gaskets are junk as was the cork seal for the top of the accelerator pump. Made new gaskets and a cork. Checked the pump and the oil softened the cup. Put it all together and it fired right up! Even got a chance to look thru original manuals for the truck, very nicely written, it is fully illustrated like the half track manuals from England.
Pics for your enjoyment and a video...
https://www.youtube.com/watch?v=wcrE4OGsRs0
