Another Ahab
- 4,967
- 113
- Alexandria, VA
Like the back-up lights: that standard?
No. Just an add on for the CUCV since it is used for plowing (you can see the plow attached in the first pic).Like the back-up lights: that standard?
Hi,
I also did the same thing to my 1986 M1009, This summer I will paint the 2 greens and black canadian camo!
oh I didn't think of that lol I would only need the cable and plastic piece as I have all the original bracket someone took it apart before I bought this truck it would be nice to have it back originalHi 76Chevy. I have no idea where you could find an original throttle lock for your truck. If you are looking for functionality over form, try adapting a old tractor throttle cable assy.
I would appreciate it!! any pics you might have would be great as well. Measurements of bends and angles would make my year.I still have mine I could measure it give you with and length I know its 1/4inch thick steel
no not backwards if you look you see the back and front bolt it needs to move ahead the back bolt is supposed to be in that hole you see and the belly plate bolts flush to the rear cross memberI would appreciate it!! any pics you might have would be great as well. Measurements of bends and angles would make my year.
These are some pics I have of one but I believe it is installed backwards. If I cant find an original I would like to have them reproduced for others in need.
Thanks!!!
