Can't fix my transmission issue.
vitamink
Indianapolis, IN
I've written about this in the past. I have pulled this thing no less than 3 times, replaced every seal and it still leaks. The transmission fluid seems to be coming from the trans shroud. Any Ideas? Both the trans and transfer case are new. The puddle of transmission fluid is about 1 days worth.
WILDBOY6X6
Newark ca
I would ask 1st if the trans is new or a remand unit, when you had it out did you see any wear marks on the converter seal area?
The seal can leave grooves in the converter some times they make a sleeve to put over the surface to give the seal a smooth fit.
I would also say to check (you can in truck) to see if its coming from the gasket on the front pump and not the seal.
I only say this because the seal will not make it leak after sitting a while but the gasket will. I hope this helps.
Steve
NDT
7,501
Camp Wood/LC, TX
Pull the cover and pressure wash everything, then inspect with the cover off, before and after operation.
Retiredwarhorses
4,617
Brentwood, Calif
The cover,can't come off without removing the exhaust crossover, and the starter...a wonderful design.
leak points...modulator o-ring, shift shaft seal, trans kickdown sensor seal, tranny dip stick tube seal.
those are,easy fixes and visible....then theres main converter seal and pump seal.
if it's in Leaking from the drain hole it most likely the front seal...but,removing the cover and getting a visual
will show you where it's coming from....but as stated above. Get it cleaned up....wipe it down wit brake cleaner.
Jeepsinker
470
Dry Creek, Louisiana
That isn't the pan gasket. Someone probably put a new pump seal in without replacing the pump bushing. It will always leak until that bushing gets replaced. Either that or the converter is cracked. When you bolt up the converter to the flexplate, do you get proper converter drop? If not the convert or will be tight but cocked slightly sideways causing a leak.
