cant get the m1031 to run
84cucv1ton
New Jersey
a buddy of mine got two of these for 2k. he made out real well. someone here said to disconnect the glow plugs. try some staring fluid. both started. ran for a good hour or more. hooked the plugs back up. one is great. other one still does not want to start. checked everything i can think of. all seems good. whats am i missing????
thanks
FMJ
37
Las Cruces, NM
I had 8 bad glow plugs on my 1008 when I got it, wouldn't start till I changed them, also check the GP solenoid on the firewall with the key on when cold you should have 12-24 volts on both the big lugs when you first turn the key to the run position, if not the glow plug controller may not be working.
84cucv1ton
New Jersey
very true. i dont blame you at all.
thanks for the help. got it running. the little card under the dash, burnt somehow. put in a push button. new 1000 cca batteries and a new starter. think it was called a 28mt. something like that. way lighter and easy to put up to. blend the line. came to life. starts good and easy now. thanks for the help
CCATLETT1984
Saint Clair Shores, MI
there is a small square chip with three pins on the edge farthest from the gold contacts, does it look burnt?
the chip is usually the culprit. I happen to have a few extra from when i had to get one in the past.
