Roger Friedrich
- 1
- 8
- Cape Girardeau,MO
I have a 1963 M37 that had the carb rebuilt by a guy who was a mechanic in the Army and the rebuild is great but...... When the M37 sets for anytime it need to use ether which gets it running and when you start it after that it will start without ether. The mechanic purchased the rebuild kit and cooked the carb before he put the kit in and he's also baffled. He has worked on several military truck as a civilian and a mechanic all his life and has many of the gages that are used to set the float and other things
So this is my request to see if anyone has any ideas what be the problem.
A few other things is I purchase gas that has no alcohol - I use Seafoam to help keep the gas from going bad - the tank has been Red Coated which I had to dump the first tank due to the Red Coat - I have checked the fuel pump and it does work but not sure of the pressure to the carb - it does have a glass bowl with the screen fuel pump
Any thought on other areas to check would be appreciated
