Cargo Cover
emr
24
landing , new jersey
Well i do not have a pic but put the end curtains on first and one loops the rope arond the bow thru each hole, but first make sure it is centered and when done will have same amount hanging out both sides, then throw the tarp over the bows and center as much as possible, there is no front or back on a canvas cover, , there may be one printed but all do not have it, the way to ty the ropes off on the sides are generally 2 loops and then around the back up thru the center and over the loops and push thru the end of the metal loop, this may not make sense untill u do it, they should all be the same and be neet. well sorry it makes less sence reading it , but hope this will be a starting point....
fasttruck
629
Mesa, AZ
Beg to differ with EMR but at least for 2.5 and 5t cargo covers they only fit one way. There is a front and a top. If the cover is correctlly laid out on the bows the side of the seam between each section will have the open side facing the rear of the truck. Top has buckles to tie sides up exposed.
MAXM37
Newmanstown, PA
I was able to get the cargo cover on correctly. My only concern is that the sides do not come down past the bed top. I see many different ways that covers are on truck, some where the cover does not go down all the way and some that do..... I bought my bows from Vintage Power Wagon and was under the impression, once cut in half, they would be correct. I am wondering if I need to trim them down even more?
I was hoping to have my cover in place for the Rally at Rausch Creek, but doesn't look like that will happen. Supposed to Rain hard Friday night!
