CAT 7155 Manifold rebuild
vinceM920
CONWAY, AR
R I have an M920 I put a 17ft. dump on. We are running it every day, after 20-k miles It has started to leak air in netural and 1st thru 4th or 6th gear. My Wife loves driving this truck because she has a bad ankle and knee and can not push a clutch. The truck is a reman and like new. I do not want to go to a manuel trans. in you EXP. could we pull the shift manifold thru the floorboard and just put all new O-rings in without testing it and put it back to work or would this be a waste of time. Cat wanted 4-k to 12-k to fix it I SAID NO WAY can by a new allison for that. Your thoughts??? Thanks
R Racing
17
St. Leonard, MD
Did you try and remove the air line from the out board Passanger air tank and fill it with air tool oil ? Then put it back on then let it build air and try it ?
vinceM920
CONWAY, AR
Jim, I have tryed every way I know to contact you. Please give me a call @ 501-548-5101. If you have family health issues I understand. If you cant work on the manifold just ship it back or I can send my son up to get it. Its been weeks now with no word. I'm losing $600.00 every day this truck sits.
Thanks, Vince
