CAT ET3 cable plug doesn't fit
GreyEnvy
North Mississippi
I bought an aftermarket CAT ET3 to help me troubleshoot my HEUI pump, but the plug doesn't fit my A1-early socket.
My truck has two smaller pins at 1 and 4 o'clock, but the adapter has large plugs in those locations.
Ideas? Are the military plugs just different? Is my aftermarket just junk?
I could:
1. Buy a better cable that fits (will it? Which one?)
2. Try to file down the plugs to fit (if even possible)
3. Pull the pins out of the socket and manually place them in the plug (janky and doesn't solve the problem for the future)
MrMikey4026
417
Eatonville Washington
I could:
4. Set my truck on fire (fun but expensive) View attachment 883766
I converted my truck to the 9 pin J1939 socket.
I think I purchased it on Amazon about 3 years ago..
87cr250r
1,988
Rodeo, Ca
Cat HEUI? Replace the injector harness and then troubleshoot. Last I bought one it was $90 for the harness. You can visually inspect the pins on the injectors.
