FreightTrain
Banned
- 2,730
- 13
- 0
- Gadsden,Al
Changed my fuel and air filter today(package from Ted's showed up...) and was horrified when I pulled the old filters out.The fuel in the primary on the frame rail looked great.Clean,Clear,Re.....uhhh,Gree....Dumped the fuel back into the tank and towards the end I saw a flake go by so I stopped and dumped the rest in a bowl.I found 2 table spoons worth of chunks in the there.The filter was totally clogged and the bottom of the can was full.Pulled the secondaries off and the fuel was a black color with a massive gasoline smell(I ran a tank of 87 octane a little while ago.)The front had about as much rust,dirt,and other chunks in it as the primary.The rear ws much cleaner but there was a little sedament in the bottom.Luckly I the filters all did their jobs.But just cause your truck is running good doesn't mean all is well.If you don't know when they were changed last....DO IT NOW!If one of those chunks had made it past the final filter I would be on here looking for a IP and putting in my new injectors that I already have.
