Changing the rear springs on my M1031
Jozseph
New York
FWIW
I am changing my rear spring on my 1986 M1031
Using Dayton Made in USA springs 22-617HD, (10 Leaves, 4,650 lbs capacity - my opinion it is always better to have more capacity.
ORD Rear SuperShackles Direct replacement size.
ORD greasable rear suspension bushings: greasable bolts with greasable poly bushings.
ORD Ubolt Reversal Kits.
Sent everything out to get powder coated flat black.
Regards
Joseph
Drock
9
Eatonton GA
Do they have the over load spring on top like the stock ones? If so, you may have clearance issues with the U-bolt flip and the bump stop, if your not lifting the truck.
Jozseph
New York
No there is no overload spring, the overload spring that GM put on are the same that where used on DRW civilian trucks.
The pack thickness is 4-3/8 inches for the 22-617HD springs
I am installing them in a spring shop, have available tooling and material to manufacture u-bolts on site
Joseph
Jozseph
New York
What did you do for front springs?
My plan is;
Dayton (Made in USA) Front Springs 22-402HD
4 Leaves Full taper.
Pack Thick - 1-15/16" , Spring Capacity at Pad 1,900 lbs
Add the Dayton Tapered Extra Leave - 22-402XL
This will add 500lb of captacy
This will be a total of 5 leaves with 2,400lb total capacity per spring.
Regards
Joseph
LT67
499
Bowdon, GA
My plan is;
Regards
Joseph
I have new springs on my M1008 and the front is a factory type 4 leaf set up. Thank gawd the 35's smooth out the ride.....
Jozseph
New York
Which brand of spring did you installed?
Is the main spring a regular wrap eye or a reverse wrap eye?
Would you recall the part number of the spring?
Weight capacity?
Thank You
Joseph
LT67
499
Bowdon, GA
Weight capacity?
Thank You
Joseph
To be honest I really don't know. A local spring shop ordered the factory 3 leaf set up for a diesel and then added another leaf if I remember correctly. The front springs barely have a negative arch now. I can take a pic of it tomorrow when it's daylight.....
1,814
The 22-617HD part number has popped up before as a Dayton number. I can't recall the exact conversation but it was inferred that there is a chinese equivalent of the same PN that is inferior. I need to do springs on my V30 but fear getting a copy of the 22-617HD.
Jozseph
New York
Mind sharing what powder coating cost on those parts ?
2 rear springs; 20 pieces, 4 brackets, 2 ORD SuperShackles, 4 ORD front hd shackles, 2 ORD Offset 1" Zero Rate Add a Leaves , Ubolt Reversal Kit; 4 u-bolts, the 2 plate and 6 rivets
All sandblasted to bare metal and powder coated flat black
cost was $400.00
Joseph
Jozseph
New York
Go to a local Dayton Spring Dealer, that is what I did as I had the same concern as it appears all spring manufactures/sellers use the same part numbers.
The Dayton Springs are manufactured in Harrisburg, PA - I spoke with Dayton Tech Support
There is also a Dayton Factory Sticker / Label on the Springs
FWIW I took the factory stickers off can post a photo if you would like.
Regards
Joseph
LT67
499
Bowdon, GA
Thank You
Joseph
Got busy with work yesterday..... here's the pics of my 4 leaf set up on the front with a 35in BFG KM2. As I previously mentioned, if it weren't for the 35's the truck would be unbearable to ride in. It had 33's on it when I got it out of the spring shop and the ride was unbearable.
Jozseph
New York
I installed the rear springs this Saturday 11-11-2017
Some photo's
ORD Greasable Bushing
notice the molded groves for grease
Installed ORD Rear SuperShackles
ORD Supershackel with Greasable Bushig and Bolts Front.jpg ORD Supershackel with Greasable Bushig and Bolts Back.jpg
Front View Back View
Original Springs M1031
New Dayton 22-617HD Rear Springs installed on M1031
Regards
Joseph
