Charge 12v batt in 24v truck
LiqTenEXp
NJ
haha, I had 5 Ton on my brain. All my specifics are useless then. If you had a wiring diagram for its charging system I could come up with a similar concept, I think you get the idea...
Sorry
mm58
9
Tucson/Arizona
Oh no problem, I should have mentioned what truck I had in the beginning. Anyway, yes I get the basic idea and I will sketch out some ideas for how to hook everything up.
Basically, I'd like the batteries to charge from the alternator when the truck is running, and then switch to the solar panels when the engine is off. Might have to get a different charge controller for the solar
Jeepsinker
329
Dry Creek, Louisiana
Ok, you should be able to daisy chain at least two of them to get 24v output but that will leave you with a third panel you can't do anything with because you don't want 36v. If they were higher quality panels you could run an infinite number of them at 24v.
MarcusOReallyus
811
Virginia
Hmmm, that sounds like a possibility. Actually, the fridge will run on either 12 or 24. So maybe I should do this:
*Get a second battery and connect in series to the other one to have 24v.
*Run the fridge on 24v
*Charge the batteries from the 24v alternator just like the
trucks main batteries.
This is, by FAR, your simplest solution. Add a battery isolator to make sure you don't drain your starting batteries, and done.
If you want to buy a new solar charge controller to use your existing panels, that's good too.
Anything else is unnecessary complication and asking for trouble.
swbradley1
Modertator
1,582
Dayton, OH
+1
I hate seeing complex when simple will do.
glassk
Hampton, GA
It's a HF solar system. Only 45 watts and designed for a 12v battery. It's three panels of 15w each
Add a relay in between the controller and let the input from one truck battery go to the Normally open terminal then the panels go to the Normally closed , when truck ignition is on the relay will energize and let power go to controller from truck battery, when turned off relay uses panels,
mm58
9
Tucson/Arizona
This is great! I appreciate all the input guys.
Can anyone suggest a place where I can get the above mentioned relay?
Mike
mm58
9
Tucson/Arizona
I found a relay today at a local electronics parts place. It's an NTE R04-11D30-24. A lot heavier duty than I probably need, but that's okay with me.
Now I just need to find a 24v battery isolator...
MarcusOReallyus
811
Virginia
Eh. Yes, that will work, but I'd be hesitant to use an open relay like that. Too easy for grime and gunk to get into the contacts. You could always put it in a small electronics kit box, I suppose.
mm58
9
Tucson/Arizona
True enough. I'm gonna have to make some kind of cover for it, or enclose the whole shebang in a box.
swbradley1
Modertator
1,582
Dayton, OH
You could also get a project box from MCM Electronics and the grommets for the holes and wire loom materials.
