cheap 10 ton
swbradley1
Modertator
1,945
Dayton, OH
Hundy (100dollarman) should buy it :)
Yeah, that's it. He should buy it and park it at my house. I'll even wipe the drool off of it daily.
Not sure if the Boss would want me to have two wenches on the property though....
sw
art
31
Northern N.J.
It's a E2 Gasser
Sold! :cry:
This listing has ended. Try finding a similar item.
Item:1969 Mack 123E2
Hope someone got it! :driver:
fasttruck
638
Mesa, AZ
The army's 20 ton rough terain crane also used a 903 to power the chassis. The bradley fighting vehicle uses a turbocharged 903.
ALFA2
Phoenix, Arizona
Congratulations, Andy 1234 that is a good looking truck, great price, and it's a Mack on top of that !
You will have fun getting it to be all you want it to be.
ALFA2
jrou111
Birmingham, AL
He was probably using a trailer dolley because the height of the 5th wheel on th M123 is too high for most trailers AND it uses a larger pin than most 5th wheels. The plate on the dolley is probably on backwards because it's easier to lower the trailer in front of the dolley and pull forward and lock the pin than to try and back up a dolley the conventional way.
73m819
329
gainesville, ga.
the second 5th wheel is another 10t 5th wheel, the reason the truck 5th wheel is backwards is with 2 winches, the cable will tend to pull into the V of the 5th wheel on a low pull, thus a side pull on the winch even with level wind and the cable wont spool right. it looks like the truck was used for winching (pulling beams under a building) and the dolly was used on the structure move
Andy1234
13
St. Louis, Missouri
It runs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:-D:-D:-D:-D:-D
I talked to the guys at the lot in Sandy Eggo, and it fires right up!!!!!:-D:-D:-D
Looks like it'll be headed to StL next week:-D (on a trailer, I'm not driving that home...:wink:).
Andy
