5tonpuller
- 28
- 28
- Thompson, Pa
Any body try the pressure washer on from northern?
[/quote]disco said:Ah, pressure washer sand blaster. I haven't seen that yet. The local store doesn't have it in stock. Do you have a link?
Visit www.badboyblasters.com and you will see we sell quality blasters.BKinzey said:Got one from Northern Tool. They all look about the same.
Using 30 grit sand, not the play sand. The ceramic nozzle lasted about 2 minutes
Still worked pretty well though until I released the deadman valve. Then the hose would fill up with sand and my next spray would be a 2 to 3 second fountain of sand until the hose cleared. I think part of this is due to the valve getting gritty and often didn't shut off completely
Didn't somebody say these worked fairly well? I'm not too pleased but I figure I'm probably part of the problem.
Any suggestions?
Go to www.badboyblasters.com and we sell complete blasters and also vacuum syatems for themdisco said:I'm working on making a blasting cabinet. I will attach a shop vac (Rigid brand actually) with a HEPA type filter to the cabinet. I'm not sure if that alone will cut it so I also have a two cartridge mask I'm wearing. I think if I buy more outlet hose, I can pipe it outside and get away with not wearing a mask entirely. The shop vac moves way more CFM of air than the compressor so I should have lower air pressure inside the cabinet. No dust should escape.
Has anybody else done anything like this?
