- 3,987
- 2,797
- 113
- Hiawassee, Georgia
I made an interesting discovery today on my MEP-003A GenSet. I removed the lower cover where the power output cables are attached to the bottom of the output connectors. I had never had this cover off before. Three of the nuts, L2, L3 and L0,securing the cables to the connectors were loose and half unscrewed. The fourth nut for L1 was missing. I found the washer for L1 in the bottom, but the nut is nowhere to be found. The interesting thing is that i never experienced any problems and I have tested the genset twice in the past at very high loadings, with no difficulty. Obviously, the vibrations from the engine, along with transportation vibriations (M116A2 trailer mounted) have loosened the nuts.
I would recommend that everyone with an MEP-003A or similar GenSet check the nuts on their units.
