Check your Feedthru Terminal and Ground
twisted60
250
Jupiter, Florida
I was rolling around on the creeper yesterday and found an issue, truck started fine (only drove in and out of garage, still waiting on SF97).
Anyway I found that the Feedthru Terminal , TM 9-2320-280-24P-1 figure 69 *a
from battery box thru the body was not tight, inside battery box where you can see it was fine, but under the HMMWV it was loose along with the ground bolt,
TM 9-2320-280-24P-1 #33
that passes thru the shunt to the underside of the body.
I was surprised the truck started and I was not having any noticeable electrical issues.
First pic is the before, you can't see but the Positive connection on the Feedthru was loose also. Second pic is a new bolt 1/2"x3", it appears private Snuffy had installed the wrong thread nut on the Feedthru and striped it, ground was just not tightened correctly.
So double check those connections, I could have fried some electrics or possible my EESS box, waiting for new Feedthru to arrive, ordered last night from Kascar.
twisted60
250
Jupiter, Florida
Looks like it's time to replace the cable in picture #1 that's a lot of cracking on the insulation.
Good eye, it's on my to do list, . I plan to replace all battery cables soon, just need to find a deal on 00 cable, I have enough 0 cable but not sure it's heavy enough. Thoughts ? 0 vs 00 cable for batteries.
juanprado
2,898
Metairie/La (N'awlins)
Lots of time it is the carc overspray paint that is cracking on wires, not the wires. Can't really tell if those are oversprayed?
twisted60
250
Jupiter, Florida
Overspray is probably correct, my HMMWV has probably the worst paint job on her belly, not sure if they use undercoating or not but it looks like paint on top of sticky black grease. Paint just comes off in sheets. My drive way looks like digital camo from all the chips i keep removing.
I'll take a closer look tomorrow at wires and see if it's overspray.
