Checking Brakes and Steering on My 83 M35A2
JHutch
116
33
Tennessee
That looks like it’s it. Wish mine still had the On/Off : high /low plate still on it. I will check toggle while Truck Master is off to see if it’s got three positions. I have never touched it as of yet. But I will tomorrow.
Thank You
JHutch
116
33
Tennessee
By the photo of mine. It looks like the heater is in low. The defroster and heater knobs are pulled out a bit. I will take larger photo of dash and how mine is set. I ran Her engine for 40’minutes yesterday morning and didn’t notice heater or defroster on. Never thought it was on any time I ran engine.
JHutch
116
33
Tennessee
Yes the toggle is the 3 way. I put it in the center (off) position.
The Defroster and the Damper knobs are pulled out a bit. That’s the way they were when I got Her. Is that a problem ? Now the power toggle is off.
I never heard or felt the heater being on at all while I have ran the engine and the one short trip I took.
Also the Air Filter tube is not there.
I will check to see if filter is good.
Thank You
JHutch
116
33
Tennessee
I found the Manual that is mine or very close.
It shows the Toggle switch
Wish mine had the plate with the info on it.
Thank You
LowTech
162
Arizona
I Put grease in the front wheels to feed the boots. I put in 10 good pumps on each. The boot that has not been changed to the zipper boot feels like it can take more grease. The zipper boot seemed to give resistance after 10 pumps. I feel that one is full. Gonna add more to other boot. If I see boot enlarge I will stop.
Will be going after All the fittings I see.
Manuals are a great help
Just catching up here,
Are you saying that you're attempting to fill the boots w/ grease!?
Those boots on the front axle are not supposed to be grease filled, they're just dust covers.
. . . sent without me knowing . . .
JHutch
116
33
Tennessee
Thank You
The manual says GAA. / I see that they had grease added there. I added more.
LowTech
162
Arizona
This is a quote from a thread called "Zipper boot replacement"
"If you have grease oil inside the boots then you have other problems
The nomenclature is dust boot not oil boot."
That is how I've always known them.
LowTech
162
Arizona
Post #12 on this recent thread says the same thing,
Greasing a Deuce
JHutch
116
33
Tennessee
I added grease to the grade fitting on the top. Where the manual said to put it. I did not remove the boot. There is zipper boot that was installed on the drivers side. The clamp is secured tightly.
Thank you
JHutch
116
33
Tennessee
Thank you
I added grease to the grease fitting
X out grade
JHutch
116
33
Tennessee
Hello Guys. An update. Found a guy that can do the Brakes on the Deuce. Awesome
He rebuilds farm tractors and worked on Big Rigs. Also Drove them for yrs.
During summer he does mower repair.
The fall is when He can do it. I fully understand. He’s Gotta nice shop 👍🏼
I will send in process photos.
Thanks Guys. JHutch
JHutch
116
33
Tennessee
Guys. The guy doing the brakes was asking about if the parts still available. Truck 42 yrs old. / cylinder seals and any other parts you guys think I should get. I thought I had the manual with the part #s but I don’t.
Please - help would be Great with Information on part #s and links to get parts.
Thank You Guys
JHutch
20,697
Thank You Guys
JHutch
Yessir. There is a spreadsheet of Deuce Parts.
Give it a look.
  • Like
Reactions: HDN
JHutch
116
33
Tennessee
Gonna be getting New Wheel Cylinders and Not the kits. More $ but The Guys hasn’t rebuilt one in yrs. Me I haven’t rebuilt one in Decades. So New Cylinders it is. More $ But Better off.
Thanks Guys 👍🏼
JHutch
