goatijoe
- 0
- 16
- fort mill sc
I have made a easy pump set up for wmo or atf. Here all i used for it was a air powered pump from harbor freight $80, 2 goldnrod filter housings from northern tool $40 apiece, 1 golden rod mesh strainer $18, 2 3/4in. x1.5 in. pipe $3 apiece, 1 3/4in. x male hosepipe thread $4, 1 50ft. hose pipe $10, and a hosepipe valve $2 all pipe, hose, and fitting from lowes. Start with putting the pump together, thread one nipple into the pump and a filter housing, then thread nipple in to the next housing, hosepipe fitting next then to to hose pipe and the valve on the end. The first filter housing take the filter out of it and replace it with the strainer that you bought and keep the filter for a spar for the other housing. This set up works great with air off the deuce its a bit slow or even faster off a compressor. All the stuff is only 200 bucks that is only 2 tanks of fuel and its paid for. A plus for me i have a unlimited supply of watf or wmo so i don't have a worry with having to buy it. I will in the next coming days to get a picture of it all set up and working next time i go get some oil with it. ![Git-r-done :grd: :grd:](https://www.steelsoldiers.com/images/smilies/grd.gif)
