acmunro
- 4
- 18
- Reynoldsville,PA
Good day, would a chevy 3/4 Ton Front axle bolt into a M1008 ? I know the spring perches on the rear axles are different. I did not hear or could not find any info on the front perches. I know the rotors and calipers, U joint, etc would be different. Mostly concerned about the perch width and what I will run into with the steering. Thank you
