Westech
CPL
- 6,104
- 211
- 63
- cow farts, Wisconsin
Thank you. That is a picture from when I was in prison.
Im just a newby dumbA$$ but Im more familiar with Air brakes. Is the parking brake on a Deuce mechanical with a cable the axles shoes ore does it have a drum/ disc on the back of the transmission/ transferr case.
The reason I ask is a few years ago I had a friend get pinned by his truck an old Ford F700. It had air/hydraulic brakes and a mechanical park brake. He left it in a higher gear and chocked it with a rubber chock with a hollow bottom . It was on wet ground and the parking brakes let go from a bad cable. Ht was pinned to a chain link gate for an hour. He asked about a fix and i took the brake disk on the transmission park brake and put an air brake caliper off an old Mack on the set up. I used a lock down valve and control from the same truck and dash mounted the control knob. Then added a lock down brake chamber and slack adjuster. It works really well.
..or stop engine and put the transmission in gear (forward or reverse depending on incline)....
Trick for chocking wheels when your parking brake is toast, you know it, and you're on an incline - tie a rope to the chock and toss it down from the door to the downhill side of the tire (can be difficult) then roll up to it. Chock the rest of the wheels normally. When you want to leave, remove all chocks except the roped one, grab the rope, get in, move off it and haul it back... hope you used a long rope.
You can also make a jig to hold the engine stop cable out for those emergencies where you REALLY need to stay stopped. (Also is handy for shows) Just split a piece of copper tube down the middle, cut to length of just a bit farther than you normally pull out your ENGINE STOP. Kill the engine, insert your jig, and you can leave her in gear.
I had to do this recently when I got home from a trip, set the parking brake to hop out and chock the wheels, and when I let my foot off the service brake the truck just started rolling backwards again.
Time to fix the parking brake!
That can still start the truck! Especially a muilti.....or stop engine and put the transmission in gear (forward or reverse depending on incline).
