- 8,693
- 3,179
- 113
- Monrovia, Ca.
Talk about reviving an old thread! See what search can do
What holds the new ones on? The deuce has a nut on the front of the shaft.I went through the ^same^ effort with similar results. Tuesday after calling Napa and Carquest only to be told the parts were no longer available, I called Baxter Auto Parts in Portland. They cross referenced the numbers and had the
Anco 41-01 Wiper Arm
Anco 31-13 13" Wiper Blade
In stock. They come with a splined bushing with internal splined taper that fits the shaft on the Deuce wiper motor perfectly. They fit great, were easy to put on, and even came in 383 Green!
Will upload video of them working, if in fact they do actually work.
On a related note, it turns out that the reason my wipers weren't working to begin with is that the tapered splined bushing on the stock was stripped so that the wiper just spun in the wiper arm.
Yes. The deuce and the 5 ton have the same cab, and nearly everything on them is interchangeable.are they the same as the 5 ton wipers
QFTThe 800 series five tons have the same cab. The 900 series 5 ton has a different cab. I think the 900 series have different wipers (with a park function) but may have the same shaft.
bumpPicture looks good. Do the 13" blades hit the window frame? I've read a lot of posts where some modifications to the arm have to be made to use the 13" blades, but the 11" blades can be used with no mods required.
