REDWOLF
- 0
- 0
- Risingsun Maryland
I am shure somone on here has installed a class tree reciver on there blazer. What all has to be changed to do this. Can i keep the pentail hook and everything eles or does it have to go. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Depends on what you plan on towing/HOW Heavy Duty You NEED it to be, the hitch...I am share somone on here has installed a class tree reciver on there blazer. What all has to be changed to do this. Can i keep the pentail hook and everything eles or does it have to go.![]()
As seen from this pic I found on the I-net, the hitch can be done, but it will need to stick out far enough to be able to clear the pential hitch (If you plan on keeping it. So, a frame mounted one would be best. As far as I can tell, you really don't need to move anything so long as the hitch drops down far enough to clear the bumper. I suggest taking some measurements. Measure from the bottom of the frame (Where the hitch will be mounted) down to the bottom of the bumper. You need to figure out how low the bumper sits so you can get a hitch with a tall enough mounting bracket to clear it. Other then that, I say, DO IT!! and then post pics to show us how it went!![]()
